Sylvania SYTABEX7 Owners: Must Read
Discussion in 'Sylvania Tablets' started by JPardee, Mar 26, 2011.
  1. Cat88Extreme
    Cat88Extreme Member
    Ohio
    Sylvania Sytabex7
    I went to a CVS that I know had sold (I had tried to buy one a month ago) and they had them in stock again.
  2. Eggplanto
    Eggplanto Member
    I've had the SYTABEX7 for about 3 months now and my frustration continues to grow. When I first got it, almost nothing would run. I did the 2.2 update and performance was definately better- I could run SOME apps without them crashing but still the device had problems like: the card reader fails to read the card most of the time (I've tried multiple cards), the wifi connection will frequently drop, and as of last week, whenever I turn on the device, it comes up to the "calibrate" screen so it loses all my settings every time I turn it off and on. At this point, the tablet is pretty useless. Has anybody else had these problems, and if so, is there a way to fix them? Does anybody know how to go about returning the device to the manufacturer to get it fixed or replaced? Thanks
  3. cfrockit
    cfrockit Senior Member
    Sylvania SYNET7LP
    It's understandable that while this is a consumer product it does need a little patience to get the most out of it. A few questions/suggestions -
    • Did you use beta4 for the upgrade to 2.2? It has been reported as the most stable and resolve the most issues. If not, try upgrading again using that file.
    • If you did use beta4, have you done a "Factory Reset" from the Settings screen? This will wipe all user data and clear off reference to all installed programs and settings so if there was an issue with some data corruption it should clear the problem. This also works when programs wont install because the device reports 0.0 free space. Try this version of factory reset.
    • If you've done that and already been using beta4 did you do a "Factory Reset (three finger method)"? This is always a good procedure if you don't know what's going on and are willing to reload all programs and settings.
    • Finally, if you're really not willing to attempt any of these you can always contact Customer Support online http://digitalgadgets.com/contact-us.php
    Good luck and report back if anything works including contacting Customer Support.
    • Like Like x 4
  4. Eggplanto
    Eggplanto Member
    Thanks a bunch for the information and suggestions. My device does have beta4 for 2.2. I've tried the various resets and none of them have improved the device, so I'm at the point where I'll contact Customer Support and see if they can replace or fix the tablet. Would you know if the warranty is still good since I upgraded the device to 2.2? Is that "beta4" upgrade something "official" from the company or did I void the warranty by upgrading? Thanks
  5. netcoord99
    netcoord99 Member
    Coldwater, Michigan
    sylvania SYNET7LP
    Speaking of "Must Read".. did I pull a major boo boo? I pushed the reset button on the back of this sytabex7 tablet. Did that or something else wipe all my apps off it and set me back so I can't even download free apps anymore? If not, why can't I get free apps now? I get an error now saying download failed?
  6. petedude
    petedude Member
    SoCal
    generic 7" MID PL7B
    Forgive me if someone else mentioned this already, but did you upgrade the wireless driver? I've done this and helps with the wireless issues. There's also some wireless setting tweak mentioned around these parts that supposedly helps with power consumption as well as performance.
  7. mardow
    mardow Member
    Chicago, Illinois
    Sylania Tab EX
    My tablet reset on me and I lost all my settings. After it came up as a stock system running 2.1 I tried the system update. To my great surprise it worked. I now have android 2.2 running. The following is what I get from a system status:
    Model number
    SYTABEX7
    Android version
    DG2.2.1-7b1
    Kernel version
    2.6.32.9
  8. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    I thinks thats just a problem with one of the cache folders, I know I've heard that problem before. I know I'm gonna spell this wrong, but I think it's the Delvchek-Cache....yeah that spelling HAS to be wrong, but I'm sure someone here will correct me.
    Pressing the reset button on the back simply turns the tablet immediately off. Nothing to worry about that.
  9. lorenii
    lorenii Senior Member
    Dalvik cache.
    < / end Spelling Nazi>
    • Like Like x 2
  10. lohtse
    lohtse Member
    uk
    3x chinese clones(flytouch),1XDisgo6000,2xAndroid Phones,
    lol thats the first and probably only time update as ever happened lol
  11. srrao
    srrao Member
    United States
    SYNET7LP
    Can you please advise what was the problem you were facing with USB port?
    • Like Like x 2
  12. Glassman
    Glassman Member
    fayetteville, nc 28301
    sylvania SYTAB10ST
    I bought a couple of the sylvania sytab10st's and as soon as I turned on the first unit it froze. I waited until its battery died down which is what I do with my Ipod when it acts up as well. it worked okay for a few minutes and started doing the same thing. "freezing" now it does'nt turn on at all. I looked in the user guide for help and found the web site and phone number. so far its been a week and no one has returned my call from the message I left asking to be contacted. I am now trying to get some answers from their website and have been just as unsuccessful. I know they were inexpensive units but I still dont believe I should lose my money which is how I'm starting to feel. I would appreciate any advice on what to do about this matter. I was planning to buy three more for chistmas to give to my kids but Don't think it would be a wise desicion at this point.
  13. kisstink33
    kisstink33 Member
    indiana
    synet7lp
    well i can i just say that my tablet exploded in my kids hands while he was playing a game it was not hot or over charged
  14. mre123
    mre123 Member
    United Kingdom
    Disgo 7000
    My tablet is not charging anymore..........it starts and goes off when i press power button. Adapter is working fine on other devices. Can anyone help ??
dgsupport digital gadgets tablet
digital gadgets sylvania tablet pc support
how to root sytabex7
sylvania sytabex7
sylvania sytabex7-2
sylvania tablet specs
sylvania tablet user guide sytabex7-2
sytabex7
sytabex7 root explorer
upgrade sytab7mx
