Installed TnT G-Harmony 1.2
Tried to follow the following steps as in the sticky
1. After Market starts, I've tried to sign into my google account. It failed. So I guess that's what the problem is.
So I tried 1-3 several times. Each time, step 4 went back to the same screen as in step 1: "Add a google account"
Rebooted several times, same thing
Is there any other tricks?
In the other sticky, the linked page says that you have to partition. Is that necessary? If so, what am I partitioning? Is it a single 16GB internal flash?
Thanks!
1. Launch the Market app. Once it loads close it. (Just tap the Home button)
2. Go into Settings - Applications - System Applications - Market and select "Clear Cache" then "Force Stop". (May be different for different ROMs)
3. Press back once, find "Google Services Framework" and select "Clear DATA" then "Force Stop".
4. Go back to your home screen and launch the Market App again. If you did steps 1-3 correctly you should get an error. If not, redo steps 1-3.
Thanks!
