ever since I bought this tablet, all my wifi connection (computer, cell phone, tvpad, tablet)drop every hour or less, lucky 3-4 times aday. Call ISP, they check my connect fine, modem work fine. Call router tech line, they can't find any problem. So I do another test myself. 1,When I got no signal, reboot the modem, this didn't work. 2,When I got no signal, reboot the router, it work, but may be half hour later, stop work again. 3,I change to use another router, everything same as the first router, reboot, work awhile and no connection again. Then I remember the problem was begun I brought this tablet, so I turn off the wifi on this tablet, no more signal disconnect any more as long as I keep this memo pad's wifi turn off, amusing ,isn't it? Is anyone have the same problem as me? Any one know what really happen? The work around is now I use my cell phone as hotspot to connect the tablet to get on line. Any one have a solution? Thank you.
Welcome to the Forum. Sorry to hear you are experiencing a wifi problem. I suggest you follow the directions in the link below. It would be helpful if we knew which Tablet you have. If you are having WiFi connection issues, check this thread.
Thanks for the fast respond, mine own a Asus ME173X, Andriod version 4.2.2,core version is 3.4.5 I am not good in computer, the link you provided 1, I don't know how to set. 2, I already tried, not work for me. 3, It's not my case. 4, Don't know how to do. 5,Use my cell phone as hotspot work fine, both the phone and tablet, no disconnect. 6, Will try that after this weekend, too many ppl using internet now, any disconnect effect will get me kill. PS, when disconnect, it's the whole house, all device got disconnect !)
