problem with update.zip in clockworkmod :(
schagox
20
hello, yes again me with my noob questions ajajajjaja good tell them.
decided to put the original rom (which is the default, the factory) but the problem is that by putting recovery mode (clockworkmod) applied the update and sends me error ... it should be? of memory on the local disk? (e lowered update.zip many times and keeps sending the same error) apply also to never put the factory reset. must be put in the clockworkmod to install a rom? because I did not before so I simply asia aplicava (with the former the default recovery)
if anyone has a solution will be extremely grateful
