Battery Mod, Is It Possible?
Discussion in 'Coby Generation 3 Development' started by Ricky405jr, Sep 9, 2013.
  1. Ricky405jr
    Ricky405jr Member
    Suriname
    Coby Kyros MID8042
  2. Traveller
    Traveller Super Moderator Staff Member
    Coby Kyros MID9742, Lenovo Tab 4 (8"), Dell Streak 5, Samsung Galaxy S4, Nexus 6
    The icons for the battery meter are in framework-res.apk and SystemUI.apk. Open them up with WinRAR and you can extract the battery meter images. From there you can change them to what you want.
    Using UOT Kitchen is easier however.
    • Like Like x 4
  3. Ricky405jr
    Ricky405jr Member
    Suriname
    Coby Kyros MID8042
    oki. Will try it out if I have some spare time to play around .
  4. Ricky405jr
    Ricky405jr Member
    Suriname
    Coby Kyros MID8042
    Just cooked a battery mod in the kitchen! it's working very well.
    The only thing that I had to do at first was replace the update-binary file with mine. Had a status 0 error. Then set the battery style in settings/system to default, working!.
    ThanXxx again. ;)
