Longer power cord source.
Discussion in 'Acer Iconia Tab A500 Accessories' started by Icebike, May 14, 2011.
  1. Icebike
    Icebike Senior Member
    ELK-P1216 12 Volts DC 1500 mA DC Plug-in Power Supply
    If you google "ELK-P1216" you will find other sources which may have better prices.
    Just remember, the longer the cord the more likely you (or the dog) will trip on it and yank your tablet onto the floor.
  2. pentool
    pentool Member
    Acer Iconia A500
    The problem with that is it's only 120V. If you go overseas, you can't use it with a simple adapter. (Some might not care of course.)
  3. chili_red
    chili_red Member
    Mississippi
    Acer Iconia A500, Viewsonic G-Tab
  4. Raven312
    Raven312 Member
    Chicago
    Acer Iconia A500
    OK, so here's a dumb question: you have this adapter and it plugs into the Iconia just fine?
  5. chili_red
    chili_red Member
    Mississippi
    Checking Phihongs website and the specs for the PSA18R power supply that came with my Iconia they show a 6' cord with a straight plug, so it's possible that Acer is having them custom make these with a short cord and a 90 degree plug for their own reasons.
    http://www.phihong.com/assets/pdf/PSA18R.pdf
  6. pentool
    pentool Member
    Acer Iconia A500
    Of course it's custom made. Why would it be generic conforming to some ridiculous standard? Acer will come out with a 6 foot cord that customers will be able to buy for a discounted low price of $39.95 plus $10.00 S&H and applicable sales tax.
    Better yet, the new version of Iconia will have a 2 inch power cord, so you have to crouch next to the outlet and hold the tablet while it's charging.
  7. Jress
    Jress Member
    Tampa
    A500
    Curious question... I have this car charger and the spare tips somewhere: http://www.amazon.com/Coby-Regulate...W5QT/ref=sr_1_1?ie=UTF8&qid=1305487536&sr=8-1
    The voltage is 12v, not the amperage is only 800mA and the A500 requires 1.5A. Can I use this car charger for the A500? I realize it would be slower charging, hut my main concern would be causing any damage to the tablet.
    I haven't found the spare tips yet, so I am not sure if there is one that will even fit the A500. But if I do, will this work?
  8. Icebike
    If your standard of determining if a charger "works fine" is to plug it in, I suggest you are headed for tears some day.
    You need to learn to READ charger specifications, and polarity specifications and charging connector designations.
  9. pentool
    pentool Member
    Acer Iconia A500
    I've emailed Acer to provide a third party replacement charger with longer wire (...yeah, right, that'll be the day!) But still, if you are sitting at an airport waiting for your connecting flight, you can't even plugin the damn thing to charge because it's not reaching that far. Unless of course you want to put it on the ground for someone to leave a footprint on the glass.
  10. Raven312
    Raven312 Member
    Chicago
    Acer Iconia A500
    My standard in this case (and my question, maybe not succinct enough) is if the "adapter" plug is the same size as the one we have currently and will plug into the Iconia. Trust me, I know about power specifications, wattage, amperage, polarity, etc. In other words, I was making sure that your recommendation was something that you have on hand and have tried personally. Didn't know whether or not you were going purely on the specs.
  11. robdroid
    robdroid Member
    USA
    Nook Color
    Anyone actually confirm the plug physical dimensions?
    Using a steel ruler it looks like it may be 0.70mm ID x 2.35mm OD, but it's really hard to tell without a micrometer.
    If it is 0.70 ID x 2.35mm OD then these extension cables would work: 0.7mm x 2.35mm Power Adapter Extension Cord
  12. Icebike
    The part number on the charger traces to this document http://www.phihong.com/assets/pdf/PSA18R.pdf
    In there you will find the specs. This was already posted above.
  13. robdroid
    robdroid Member
    USA
    Nook Color
    Yeah, I looked closely at the PDF- the electrical characteristics may be the same as on the AC adapter used with the A500, but it's not the same plug as used on the A500- a simple measurement with a ruler will confirm that.
    The PDF you linked shows the coax plug as "DC Output Connector 2.1 x 5.5mm Center positive Standard". The 5.5mm refers to the OD (outside diameter) of the connector plug. 5.5mm=0.21653543" there's no way the OD of the A500 DC connector is almost a 1/4" diameter. When I measured it last night- it OD looked to be about 2.3mm or so- not 5.5mm as shown in the PDF.
  14. Icebike
    2.1 mm is the diameter. 5.5 is the length.
  15. robdroid
    robdroid Member
    USA
    Nook Color
    Look again at the drawing at the bottom of the PDF- the length is 10.00mm
    To size a coax DC plug you need 3 dimensions- ID (inside diameter) OD (outside diameter) and length.
    Referring again to the PDF:
    2.1mm is the ID
    5.5mm is the OD
    10.00mm is the length
    Same electrical characteristics, different mechanical characteristics for the DC coax connector.
acer a210 port burned
android tablet poer extension
extension cord used with anthroid tablet
glass trophy cases esupport
how to draw more than 1500ma android
longer cord for acer
longer cord for my tablet
tabletscord with a same size cord
what is the size acer a210 charger
zeki tablet charger polarity
