[ROM] Huawei Ideos S7 Slim Official Firmware
Discussion in 'Huawei Ideos S7 Slim Technical' started by tri_zet, May 6, 2011.
  1. electron_theory
    electron_theory Member
    Can anyone repost/reupload the firmwares? It looks like H decided to kill the links that were posted at the top of this thread and elsewhere that I have looked...
    Edit-I managed to find the updata floating around here...Thanks to whoever had the presence of mind to post it...Sorry I don't recall who ATM...
  2. tri_zet
    tri_zet Senior Member Developer
    Jakarta
    Huawei Ideos S7
    i dont think huawei kill all the link. they are upgrading/changing their web site, perhaps there are broken code for "software" sections.
    i've downloaded some of them, will reupload it i have some time.
  3. shishko
    shishko Member
    For all of you having problem with unresponsive touchscreen after installing alternative launcher on your S7 Slim...
    I found out that during boot touchscreen is disabled and official Huawei Launcher enables it, so if you install alternative launcher, touchscreen remains disabled after reboot.
    First of all, you have to root you S7 Slim (I've done it using following article HOWTO: Unpack, Edit, and Re-Pack Boot Images - Android Wiki, just set ro.secure=0 in default.prop and add --base 0x20000000 to mkbootimg command-line). Then, copy file /system/etc/bluetooth_power.sh to your hard disk (adb pull /system/etc/bluetooth_power.sh c:\). Edit that file (c:\bluetooth_power.sh) using Notepad++ and add following lines:
    echo 1 > /sys/cap_touchscreen/boot_complete
    echo 1 > /sys/cap_touchscreen/state
    Then, remount /system partiton read-write (adb remount), and copy that file back (adb push c:\bluetooth_power.sh /system/etc/).
    Reboot, and now you can install any launcher you like!
  4. liosri
    liosri Member
    srilanka
    Andrid
  5. giorgitbs
    giorgitbs Member
    Hello,
    As you can see HUAWEI download site has problems. So if somebody needs - here is firmware from MTN South Africa. I'd found it on one italian forum.
    SA - HIDS70209V100R001C106B013.zip
    It's working fine on my S7 Slim. Only one problem was mentioned - Android market stucked after update. But it can be easily fixed by installing version 3.1.3 from this link:
    Download the new Android Market app today!
    Regards,
    Giorgi
    • Like Like x 2
  6. JMarty
    JMarty Member
    Hungary
    S7 Slim
    Hi!
    I uploaded V100R001C207B012(Hungary Invitel) official rom, Works with 3G/Wifi only modells both. Its newer than others. It only contains English and Hungarian languages. I dont have G-sensor problems with this fw.
    Default language is Hungarian. You have to go Menu->Beállítások->Nyelv és Billentyűzet->Nyelvválasztás to change. I hope i could help.
    Regards
    Marty
    PS: Sorry for my English, Iam from Hungary.
  7. blushco
    blushco Member
    ideos s7
    Does this work with S7-10X models? Non-slim ones
  8. JMarty
    JMarty Member
    Hungary
    S7 Slim
    This is only for Slim
  9. AntonioLV
    AntonioLV Member
    Latvia
    Huawei S7
  10. kosenn
    kosenn Senior Member
    California
    Huawei S7 Slim
    Touch screen stopped working so I used the indonesian firmware and mine is working fine again. Market app no problem. Thank you
  11. tentenbrunei
    tentenbrunei Member
    Brunei
    Huawei ideos S7
    just bought this Huawei S7 Slim few week.
    i have been tested for few firmware, but i still have auto-rotation problem.
    for the begining its working well, after few day or manybe few hours. the auto rotation wont work anymore.
    have to turn off and restart S7 slim , then my auto rotation get back to work.
    make me very piss off.
    do you guy have this issue ? anyway to solve this problem ?
    thank you !! ​
  12. loon4283
    loon4283 Member
    Are you technician from tenten brunei?
  13. kosenn
    California
    Huawei S7 Slim
  14. tentenbrunei
    tentenbrunei Member
    Brunei
    Huawei ideos S7
    thank kosenn,
    My table is 3G+ Wifi version, do you mind to share the link with the 3G version firmware ?
    thank for your hard work !!!
  15. tentenbrunei
    tentenbrunei Member
    Brunei
    Huawei ideos S7
    Hi every user of Huawei S7 Slim,
    mind to share out any update firmware ?
    Thank you.
huawei ideos s7 slim firmware
huawei ideos s7 slim firmware update
huawei ideos s7 slim upgrade
huawei ideos s7 update
huawei s7 slim firmware upgrade
huawei s7 slim tablet software update
ideos s7 slim
ideos s7 slim firmware upgrade
ideos s7 slim update
