JohnboyjrFrom that page
" Download the firmware you want, extract it and copy the entire folder called"dload" to a SD card, put it in your device and re-boot. You will see the ROM"dload" to a SD card, put it in your device and re-boot. You will see the ROM upgrade in process and at the end you will see a OK message. Take the card upgrade in process and at the end you will see a OK message. Take the card out and reboot, the only way you can is by removing the battery. You are al set. If you forget to take the card out it will go back into the ROM upgrade mode. Reply * Rep"
