Looking for Help Rooting Coby MID9740
kimbunny
9
How do i restore from a dump file? Which file in my dump folder do I use? Do I use cwm to flash it?
kimbunny
9
Can anyone help me please? Ive tried zipping my dump and installing it through cwm, I tried putting the unzipped folder into cwm backups, Ive read all the forums and none of them are clear as to how you use a dump for recovery, only how to MAKE a dump... Which Ive already done.
If I can just get back to my dump, I can try to install the gapps ics 20120429 package, and not the Coby 9740 root Gapps, because I have that now and I cant turn on my wifi.
I need help please....
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
new_version_9740_signed.zip
billshk13
download check checksum, place on sdcard
boot to cw recovery factory reset install.
Coby_9740_root_gapps.zip
you should not use factory reset from tablet if you have cw recovery install, that can cause problems
this time do factory reset from cw recovery then install
Vampirefo, the Coby_9740_root_gapps.zip file worked much better than I could have expected. I like the google interaction from your file. you did a great job on it, thank you so much. My daughter loves the fact that she can now use google play as well. I just bought you some coffee :)
billshk13
